Wireless WMPG-4 (RESOLVED)
Gixer
CNC Control System Serial Number: 0324202376
Post by Gixer »
Hi All.
I`ve got a problem with my wireless mpg-4 everything works ok except the x,y,z on the dial,feed and spindle speed work ok on the dial but if i switch it to x,y,z the dial does`nt work but everthing else will move the x,y,z.If you need anymore info let me know thats the potention meter i refer to as the dial.
Cheers
Re: Wireless WMPG-4
hi, not sure what issue you are describing can you shoot a video of what you are experiencing?
Gixer
Re: Wireless WMPG-4
Post by Gixer »
Hi here`s a video in the link let me know if it does`nt work.
cheers
Re: Wireless WMPG-4
hi thanks. please post a fresh report.zip so i can see your settings and error messages.
Re: Wireless WMPG-4
Gixer,
do the axes move using the handwheel, if you switch the increment selector to the x1 (lowest) position?
Gixer
Re: Wireless WMPG-4
Post by Gixer »
cnckeith wrote: Sun Mar 07, 2021 1:44 pm hi thanks. please post a fresh report.zip so i can see your settings and error messages.
Hi here`s my report hope it helps.
report_0008DC111213-0324202376_2021-03-08_12-09-05.zip
(5.9 MiB) Downloaded 104 times
Gixer
Re: Wireless WMPG-4
Post by Gixer »
cncsnw wrote: Sun Mar 07, 2021 5:32 pm Gixer,
Hi no they don`t everything else on the wmpg works but the axes switch but if i switch the axes switch to off you can see that works on the virtual key pad as i switch it to off then on.
Cheers
Plasma CNC Controller: Yes
Re: Wireless WMPG-4
Parameter 348 needs to be set to 15, it is currently set to ZERO
Try that and let us know.
See Tech Bulletin 313: https://www.centroidcnc.com/centroid_di ... browse.php
Gixer
Re: Wireless WMPG-4
Post by Gixer »
martyscncgarage wrote: Mon Mar 08, 2021 11:48 am Parameter 348 needs to be set to 15, it is currently set to ZERO
Hi Marty thanks for the quick fix it`s all working again i don`t know how it changed not been in the parameter settings for ages.
Anyway thanks again for the help everyone much appreciated .
Paul
jedmill67
Re: Wireless WMPG-4
Post by jedmill67 »
I just got the acornsix and my WMPG-4 is doing just what was asked about above. The WMPG-4 will do everything like it should except when it comes time to use the handwheel to jog the axis it will only move them when the selector is set to 1X. If I try 10X or 100X I get no movement. I looked at service bulletin 313 and made sure parameter 348 was set to 15. still the same thing. Any thoughts?
