Does acorn Support Glass Scales
balbino
Post by balbino »
Hi,
Will I be able to convert a machine with glass to run on an Acorn Boarrd.
Phil
Re: Does acorn Support Glass Scales
there is one encoder port on the Acorn, you can use that for a glass scale if you like. typical use in that regard is for a scale on a quill of a knee mill.
if you are asking for glass scale for positioning on three axes the answer is no. Use Oak or Allin1Dc cnc control boards for that kind of application!
https://www.centroidcnc.com/centroid_di ... y_cnc.html
