Shopbot PRS 48x96 Acorn / Clearpath Conversion
paulwall
Re: Shopbot PRS 48x96 Acorn / Clearpath Conversion
Post by paulwall »
I knew they'd be pricey, but this I wasn't expecting.
Would it be the end of the world if I ran 3/8" face-width spurs on my 0.50" width racks?
Gary Campbell
Post by Gary Campbell »
You can always give it a try, but the reality is that SB found they wouldn't hold up to the torque of their old PK series motors. Your ClearPath motors have 10 times the torque
CNC Depot Modular ATC kits
https://www.ebay.com/itm/InvolGearCuttr ... ect=mobile
Image shows #7, but the description says #6 which is what you need.
carbuthn
Post by carbuthn »
Tom,
Would he need a #6 (with a range of 17 to 20 teeth) or a #5 (with a range of 21 to 25 teeth)?
The only gears I have made was with a home-made fly cutter.
Just checking (and hoping to learn something).
Chuck
Chuck, you are correct. For some reason I was thinking he needed a 20 tooth gear!
paulwall
Post by paulwall »
I think I'm going to pursue the pinion gear stock option and have it machined into hopefully what I need and a few extras.
To keep costs down, is there any harm in running a the same 25 or 30 tooth gear on all axis's? SB used a 20 gear on Z, but I've got the bigger 3421S motor there so torque shouldn't be a problem.
I assume larger gears = longer gear service life, is that about right?
Larger gears = load spread over more teeth but also higher torque.
Gary Campbell
Paul...
To an extent that is correct. The hardness of the gears and rack, and lubrication will also play a factor. The larger the gear the less torque is available from a given motor.
The real answer is that you need to adjust your belt/gear reduction and pinion pitch diameter to achieve the desired resolution and keep the motor in its desired RPM/torque range. Use that combo to determine which torque/RPM range motor that best fits the overall design.
It would be my opinion that, yes, the Z axis would benefit from a smaller pinion (more reduction) as it always fights both gravity and inertia and operates at slower speeds than X and Y.
paulwall
Post by paulwall »
Gary Campbell wrote: Wed Sep 16, 2020 2:05 pm
I suppose that's the trouble with lack of 0.5" face spur gear availability.
Gary - Can I ask how you handle this recommendation for customers of yours who upgrade to your conversion kits?
Gary Campbell
Paul...
Depending on the application & model, I use a combination of 3 ClearPath models, 5:1 or 10:1 gearboxes, and 18,20, 24, 25 & 30T pinions to get the output to match the machine's weight, desired speed and have more than adequate torque. I try not to provide upgrades for the old PRT's with the 14.5* PA rack, only the 1/2" wide 20* PA. Even then its hard not to over torque the frame as they use a spring loaded spur to rack engagement.
I have conceded to only putting NEMA23's on PRT models
