Setup:
-2 axis lathe conversion from 12" Chinese 12x36
-Acorn Rev 4 (14455)
-CNC12 Lathe Version 4.20.1
-DYN4 servo's w/ 750w motors
-link to photo album: https://photos.google.com/album/AF1QipP ... GNOzoOUM7U
-Report attached
Initial setup went easy and mostly worked. I had a strange intermittent servo motor motion problem that was being caused by the DMM cables (w/ dropping resistor). I solved this by soldering a jumper across the DMM resistor, and connecting 5V to the brown wire on the cable. This essentially makes the connection the same as the S14888-ACORN_rev3 DMM DYN4 SERVO DRIV schematic. See pic below of red jumper wire.
After getting this working, I was snapping the plastic covers back on to the DB25 connectors when I accidentally grounded one of the pins with a screwdriver and created a ZAP! I had removed the power to the drives, but forgot to power off Acorn. STUPID!
So it looks like I fried something on the board that controls Axis-1. Axis-2 still works. I swapped cables and drives and confirmed that the problem is the Acorn output for Axis-1. Is there anyway to check these outputs with a multimeter?
Assuming that the Axis-1 is dead, is there any way to turn off Axis 1 and use Axis 3 instead? I tested Axis 3&4 and both still work. So instead of (Axis-1 = Z / Axis-2 = X), I would have(Axis-2 = Z / Axis-3 = X) The wizard will not let me set Axis 1 to N.
Also, I came across a thread where someone used the DB25 output from Acorn instead of the ring terminals. There even looks to be a way to re-map the pins. Unfortunately, I can't get any motion when I use the DB25. It provides step and direction, but not the enable signal.
Any suggestions are appreciated.
Walt
