**Resolved** No Fault Com Relay Not Closing
- CNC Control System Serial Number: Mach plugin: 1.16, FPGA:0.56, DDSP:1337.9, SN 1010120574
Firmware 442 2011/03/21, PLC1.4 - DC3IOB: No
I am making my way through the ALL in One DC setup. Trying to get the No Fault relay to pull closed. I must be missing something. Put common to "Com IN 9-12" and 24V DC to pins 9 (Also added in 10, 11 to make sure the were not faulting) on header 10. SIPs are correct. Can turn E-Stop on and off in Config Diagnostics screen. Everything in Mach looks right but the relay is not pulling closed. Fuse is Ok. My 12V Motorcycle batteries were a little low but everything looked fine on the screen. I got mist and flood relays to work while fooling around in the output screen in order to verify power to the relays. I can't hear the No Fault relay close and there is no change in the continuity. I must be missing something simple. Thanks.
Re: No Fault Com Relay Not Closing
Scott helped me figure it out. The current (1.16)download of the Ajax Plugin for Mach has the No Fault Out Brains turned off. It simply required going into Operator Tab, then Brain Control Screen and then selecting the No Fault Out brains and clicking the "Enable" box.
- CNC Control System Serial Number: GHFDDHECE(0223151234)
Re: **Resolved** No Fault Com Relay Not Closing
i am having the same issue only i am using Centroid Software. Please help if you can
