This is a new system, Dell GX620 with windows 7 premium home 64 bit. Mach 3 licensed. Ethernet will not green light ( or any ) on pc or allin1dc. The pc will get green light when connected to internet router with same grounded cat5 cable.
what gives, have swapped cat5 3 times and nothing. Pc shows network adapter is working properly
allin1dc no ether light
- CNC Control System Serial Number: A900445
Re: allin1dc no ether light
Are any LED's on the ALLIN1DC lit?
There is a row of LED's behind the limit defeater switch block, are all of those lit?
What does the 7 segment LED display?
yes, all the lights are on like they are suppose to be. I have a 4 with a flashing dot for the display. I have a DC1 hooked up and that is it, lights are good on it with a 4. for display. pc never see's the allin1dc.
Have you ever been able to connect to the Allin1dc?
Are you connected directly to the Allin1dc? No switches, routers, hardware firewalls etc..?
Are all anti-virus and software firewalls uninstalled?
In your PC, go to a command prompt and type:
ping 10.168.41.1 then press enter, what are the results?
ping 10.168.41.2 then press enter, what are the results?
no, i have not ever got a signal from allin1dc
it's connected directly
only windows 7 was installed and mach 3, firewall and updates disabled .( followed centriod allin1dc install manual )
when i ping either address i get no return signal
by the way , THANKS for the help
Problem is solved. The new PC was at fault, apparent lightening storm without a surge protector in place.
