Chinese hsd spindle
- Plasma CNC Controller: Yes
Re: Chinese hsd spindle
Marc is correct.
Provide a link to the manual for the drive. Need to see which drive parameter allows you to change the function of one of the digital inputs.
I am suspect of the "Chinglish" too. You should reach out to the manufacture or the company you bought it from for assistance.
Is there no example wiring diagram in the manual?
- CNC Control System Serial Number: 74E1829315CC-0907181194
Hi marty, hope u doing fine in the midle of corona tgins right now, Here's the link. www.megmeet-drivetech.com
I think i have written before in previous, but is ok,,
I'd like to use reverse command,, u know, in future we dont expect when u need to use it,, maybe power tapping i dont know,, thanks
Since you are the one who wants to know, perhaps you could navigate your supplier's web site; locate an English-language manual for your drive model; download it; and post it to the forum as an attachment.
Ok, i try to attach the documents here,,
hi, here the attachment for the manual, have a look, need advice from the expert.
thanks
thanks
- SPS Series Servo Drive Special for Spindle User Manual V1.1.pdf
- Manual for my driver
- (1.34 MiB) Downloaded 134 times
My best guess:
DI1 = Forward
DI2 = Reverse (Speed Position Switching)
DI8 = Fault Reset
COM = Digital Input Common
DO3+ = Drive Failure (Input X)
DO3- = Drive Failure (Acorn COM)
AI3+ = Acorn Spindle Analog Ouput +
AI3- = Acorn Spindle Analog Output COM
of course you have to set the parameters appropriately.
DI1 = Forward
DI8 = Fault Reset
On page 3-3 (p18 of the pdf), the manual lists function-selection options for the digital inputs.
You would set drive parameter P09.01 to whatever function you wanted input terminal DI2 to perform.
Referring to the more complete table on page 6-20 (p73 of the pdf), it appears that a value of 2 in P09.01 will configure DI2 for Run Reverse.
Also, if you want to use analog input AI3 for the frequency reference, then it appears you will need to set P10.01 to a value of 900.
Ok thanks marty, thanks a lot cncsnw,, i wil work on that,, wish me nothing bad is gone happen
