Hardware Axis Pairing vs Software Axis Pairing
vprasit
CNC Control System Serial Number: 3403DE6BF90A-0919192471
Post by vprasit »
I've just finished assembly a 1000x1000 mm Workbee CNC for my Waterjet project with Acorn.
This is my first project to build, so i just try it with Workbee hardware which is cheap (2.45 N.m Stepper Motor, TB6600 Driver, 8mm Lead Screw).
I've paired the Y Master and Slave Axis by Hardware pairing accordingl to the manual (Connect 2 motors from one signal) because I haven't buy Acorn Pro software yet.
So far, the machine can be moved perfectly.
By the way, I'm curious whether is there any drawback in term of Harware paring like this or not? (for example, it reduce the signal or torque for the motor or not)
If there is no effect to the Motor performance i'll just leave it Hardware paring.
But if Software paring will give it more stable or better in term of Motor or Acorn life time, I'll go for Acorn Pro for Software paring.
Please give your advice.
Here is the link of photos for my project.
Gary Campbell
Re: Hardware Axis Pairing vs Software Axis Pairing
Post by Gary Campbell »
As long as your drives total required signal current do not exceed the DB25's output (vary unlikely) there will be no difference
CNC Depot Modular ATC kits
mikes
Post by mikes »
Interesting project... What are you using for the water jet?
vprasit
Post by vprasit »
Gary Campbell wrote: Wed Jan 08, 2020 11:19 pm As long as your drives total required signal current do not exceed the DB25's output (vary unlikely) there will be no difference
Thanks for your comment. If there is no any difference, i'll just leave it hardware axis pairing like this.
I didn't connect through DB25. The connection signal is directly connect to on board terminal which is working fine.
vprasit
Post by vprasit »
mikes wrote: Wed Jan 08, 2020 11:52 pm Interesting project... What are you using for the water jet?
I've got inquiry from some food customers to cut cake, ice-cream, and vegetable.
These applications just need pure waterjet cutting (usually other hard material need abrasive waterjet).
I have demo unit of abrasive waterjet that can test cut pure waterjet for them but machine is full of dust from abrasive.
So, i build this small clean table to test cut food for these customers.
mikes
Post by mikes »
vprasit wrote: Thu Jan 09, 2020 2:04 am
Cool... Thanks for sharing. What I meant to ask is what hardware are you using to actually create the water jet? I assume something like that is pricy?
can't wait to see video of it in action cutting something.
vprasit
Post by vprasit »
mikes wrote: Thu Jan 09, 2020 2:24 pm
Yes, the pump, cutting head and high pressure tube are quite expensive. However, for soft material, we may use lower pressure to cut which the price of pump will be more economy. I hope I can complete the pump connection to table in couple of weeks. I'll keep sharing the progress after it's get wet.
