corner finder
Charlie.G
CNC Control System Serial Number: 38D2693D0BD1-0105180478MPU12
corner finder
Post by Charlie.G »
i asked this question a while back,I will try again I have gone throught my control box and
modified it from its original configuration it was the same as it was from day one running mach 3
now that I have that cleaned up and all of the acon stuff running correctly. I am interested in making
a macro for a corner finder maybe there is one here somewhere I tried to find it but to no avail.
this is a copy of the one I was using in mach 3:
Sub Main()
' 2010 Circular Pocket Probing Script
' 3-1-11
Dim FRate1, FRate2
Dim DMax, Clearance, EdgeLength, CornerClear
Dim XStart, YStart
Dim PlateOffset, XOffset, YOffset
Dim ZeroYN
Dim ToolNo
Dim ToolD
Dim ProbeD
Dim ProbeLengthX, ProbeLengthY
Dim XNew, XHit1, Xhit2, XEdge, X1, X2
Dim YNew, YHit1, YHit2, YEdge, Y1, Y2
Dim XPos, YPos, EdgeAngle, PocketXLen, PocketYLen, EdgeDelta, XCenter, YCenter
Dim XScale, YScale, ZScale
Dim CurrentAbsInc
Dim CurrentFeed
FRate1 = abs(GetUserDRO(1821))
FRate2 = abs(GetUserDRO(1822))
DMax = abs(GetUserDRO(1823))
PlateOffset = GetUserDRO(1824)
ToolNo = GetCurrentTool()
ToolD = GetToolParam(ToolNo,1)
If GetUserDRO(1829) = 0 then
ProbeD = ToolD
Else
ProbeD = GetUserDRO(1829)
End If
Clearance = abs(GetUserDRO(1825))
XOffset = GetUserDRO(1826)
YOffset = GetUserDRO(1827)
EdgeLength = abs(GetUserDRO(1828))
ProbeLengthY = GetOEMDRO(801) + DMax
XStart = GetOEMDRO(800)
YStart = GetOEMDRO(801)
If GetOEMLED(801) Then ' On = English Measure INCH
CornerClear = 1.5
Else ' Off = Metric Measure MM
CornerClear = 38
End If
If GetOEMLED(1871) Then
ZeroYN=1
Else
ZeroYN=0
End If
CurrentFeed = GetOemDRO(818) ' Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) ' Get the current G90/G91 state
'Get Axis Scale factors
XScale = GetOEMDRO(59)
YScale = GetOEMDRO(60)
ZScale = GetOEMDRO(61)
'Set All Axis' Scale to 1
Call SetOEMDRO(59,1)
Call SetOEMDRO(60,1)
Call SetOEMDRO(61,1)
Sleep(250)
'Check for Errors
If GetOemLED(16)<>0 Then ' Check for Machine Coordinates
Message "Please change to working coordinates"
Call SetOEMDRO(59,XScale)
Call SetOEMDRO(60,YScale)
Call SetOEMDRO(61,ZScale)
Sleep(250)
Exit Sub ' Exit if in Machine Coordinates
End If
If GetOemLED(825)<>0 Then
Message "Probe Grounded - Check connection and try again"
Sleep(250)
Exit Sub ' Exit if probe is tripped
End If
Code "G90"
Sleep(125)
Message "Probing for Y Center....."
Sleep(1000) 'Pause 1 second
Code "F" & FRate1
Sleep(125)
Code "G31 Y" & ProbeLengthY
While IsMoving()
Wend
YHit1 = GetVar(2001)
Y1 = YHit1 + ProbeD/2 'Tool position at probe hit.
If FRate2=0 Then
Code "G0 Y" & YStart
While IsMoving()
Wend
Else
Code "G0 Y" & YHit1 - ProbeD/4
While IsMoving()
Wend
End If
If FRate2<>0 Then
Code "F" & Frate2
Sleep(150)
While IsMoving()
Wend
While IsMoving()
Wend
End If
ProbeLengthY = YStart-DMax
Code "F" & FRate1
Sleep(125)
While IsMoving()
Wend
YHit2 = GetVar(2001)
Y2 = YHit2 - ProbeD/2 'Tool position at probe hit.
If FRate2<>0 Then
Code "G0 Y" & YHit2 + ProbeD/4
While IsMoving()
Wend
Code "F" & Frate2
Sleep(150)
While IsMoving()
Wend
End If
YPos = (Y1+Y2)/2
If ZeroYN = 1 then
Code "G0 Y" & YPos
While IsMoving()
Wend
SetOEMDRO(801,YOffset)
Sleep(150)
Else
While IsMoving()
Wend
End If
YCenter = Cstr(YOffset)
PathLength = Len(YCenter)
For X = 2 To PathLength Step 1
lstring=Mid(YCenter,X,PathLength-X+1)
If Left(lstring,1) = "." Then
LabelLength = X+5
Exit For
End If
Next X
YCenter=Left(YCenter, LabelLength)
Message "Y Center Found.........."
Sleep(150)
'X Probing
ProbeLengthX = XStart - DMax
Message "Probing for X Center....."
Sleep(250) 'Pause 1/4 second
Code "F" & FRate1
Sleep(125)
Code "G31 X" & ProbeLengthX
While IsMoving()
Wend
XHit1 = GetVar(2000)
X1 = XHit1 - ProbeD/2 'Tool position at probe hit.
If FRate2=0 Then
Code "G0 X" & XStart
While IsMoving()
Wend
Else
Code "G0 X" & XHit1 + ProbeD/4
While IsMoving()
Wend
End If
If FRate2<>0 Then
Message "Slow Probing for X position....."
Sleep(100) 'Pause 1/10 second
Code "F" & Frate2
Sleep(150)
While IsMoving()
Wend
While IsMoving()
Wend
End If
ProbeLengthX = XStart + DMax
Code "F" & FRate1
Sleep(125)
While IsMoving()
Wend
XHit2 = GetVar(2000)
X2 = XHit2 + ProbeD/2 'Tool position at probe hit.
If FRate2=0 Then
While IsMoving()
Wend
Else
Code "G0 X" & XHit2 - ProbeD/4
While IsMoving()
Wend
End If
If FRate2<>0 Then
Code "F" & Frate2
Sleep(150)
While IsMoving()
Wend
End If
XPos = (X1+X2)/2
If ZeroYN = 1 then
Code "G0 X" & XPos
While IsMoving()
Wend
SetOEMDRO(800,XOffset)
Sleep(150)
Else
While IsMoving()
Wend
End If
XCenter = Cstr(XOffset)
PathLength = Len(XCenter)
lstring=Mid(XCenter,X,PathLength-X+1)
LabelLength = X+5
Exit For
End If
Next X
XCenter=Left(XCenter, LabelLength)
Message "X Center Found.........."
Sleep(150)
SetUserLabel (9,XCenter)
SetUserLabel (10,YCenter)
Code "F" & CurrentFeed ' Reset to original feed rate
If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
End If
Sleep(250)
Message "Center Found"
If GetOemLED(1872) Then SetUserLED(1870,0)
End Sub
I don't know if this will work in acorn and I realize that I do not know enough about macros to modify it etc to make it work
thank you,
Charlie
Sword
Re: corner finder
Post by Sword »
Here's one that I've been using for years and have set up for Acorn. My plate can be used to set up for inside or outside corners. I'm not near the CNCPC today, but I can post it next week. I have plans for the plate as well. Basically a 5" x 5" 0.5 thick plate with a 2" hole dead center and a fence on one face. Flip flop for inside/outside and plug in on opposite corners.
https://drive.google.com/file/d/1Jif--e ... p=drivesdk
Scott
Charlie.G
Re: corner finder
Post by Charlie.G »
sword,
thanks for the help..I am interested in what you are doing,
I am curious though to know if the above script I posted from mach would work in centroid.
as I stated before I do not know much about macros, I am trying to learn a bit seems I never have
enough time to sit and study this stuff. I have never needed an inside corner finder. I do not use the outside
one all the time but when you need one you need one.
this is what I use made it a few years ago...
Charlie.G
Re: corner finder
Post by Charlie.G »
whoops guess the photos did not attach
thank you,
Charlie
Sword
Re: corner finder
Post by Sword »
Yeah, no, that Mach3 script won't work. You should be able to easily modify mine and set it up on a spare aux button or call it from the MDI. I'll grab it when I get back in the shop.
Scott
Charlie.G
Re: corner finder
Post by Charlie.G »
Sword,
thank you, I am not sure I know how to modify it to make it work...
I would like to learn I guess we see how it goes.
thank you,
Charlie
Sword
Re: corner finder
Post by Sword »
Hey Charlie,
Here's that macro. I changed the last part of it so it should work with your corner jig, but test it in a safe non destructive manner to verify. If you read through it, you should be able to figure out how to modify it if needed. It's up to you to be sure it's connected to the properly configured input. When I use mine, I just temporarily connect it to the same input as my moveable Z touch off plate (alligator clip it to my Z touch off plate) and then put it away when finished.
You can apply it to an available Aux button following this tutorial. viewtopic.php?f=61&t=3555
Scott
Corner Finder.mac
(2.4 KiB) Downloaded 234 times
Scott
Charlie.G
Re: corner finder
Post by Charlie.G »
sword,
thank you I will give it a try and let you know how it worked out,
thank you again for your help.
Charlie
Mkelcy
Re: corner finder
Post by Mkelcy »
I came over from the "Tool Setting Options For Router and Mills" thread. I've looked at Sword's corner setting macro and see that it calls for the probe to be tripped on PLC input 5. Is that the same as the Acorn input 5? The Acorn probe setup guide (and my machine) are setup for the probe tripped signal to be on input 7, which Centriod calls PLC input 7. Should I edit the macro to call for the probe triggered input to be on PLC input 7?
The macro, so far as I can tell, seems to be finding the center of a hole in the detection plate
I'd like to take Sword's macro and modify it to work with the detection plate shown below. Imagine it flipped over and snugged up against the lower left hand corner of a work piece. I'd like to find part X0 and Y0 by jogging over the detector, setting Z0 and then probing in the minus direction to the X "wall" and subtracting half a user specified tool diameter from the probed X to get to part X0, moving positive along X an inch or so, and then probing in the minus direction to the Y "wall" and subtracting half a user specified tool diameter from the probed Y position to arrive at a part Y0. The tool diameter would be supplied each time the macro was run.
I think I can get there, but the first step is to try to understand Sword's macro.
The depths of my ignorance on G-code programming can barely be measured, but I am working on trying to get a basic understanding.
Charlie.G
Re: corner finder
Post by Charlie.G »
I have tried this macro and I couldn't get it to work, haven't had time to mess with it but I am going to upgrade to the router version and then I will try this again. When it comes to Macros I don't know much about them but I will give it a shot.
do I need the probing license for this to function?
thank you,
Charlie
