Help needed on the best way to control a 8 position lathe turret
Re: Help needed on the best way to control a 8 position lathe turret
As Keith posted - CTRL-ALT-F on outputs cycles through three states. First press forces the output ON denoted by the green dot and the line under it. Second press of CTRL-ALT-F on the same output forces the output OFF denoted by the red dot with a line under it. The third press of CTRL-ALT-F on the same output switches it back to computer control. In this case it can be either red or green depending on the current computer state, but there will be no line under the dot. This is the state you want to leave the outputs in after experimenting.
Allin1Chris
PLC Expert
Post by Allin1Chris »
Also, Do you have your turret wired to output 1? If you force output 2 ON (Green) does your turret then stop spinning?
Centroid PLC Tutorial Videos
jumps4
CNC Control System Serial Number: 38d2697ca033-0611180974 mpu12
Post by jumps4 »
tblough wrote: Wed Sep 25, 2019 11:42 am As Keith posted - CTRL-ALT-F on outputs cycles through three states. First press forces the output ON denoted by the green dot and the line under it. Second press of CTRL-ALT-F on the same output forces the output OFF denoted by the red dot with a line under it. The third press of CTRL-ALT-F on the same output switches it back to computer control. In this case it can be either red or green depending on the current computer state, but there will be no line under the dot. This is the state you want to leave the outputs in after experimenting.
when i remove the lines the light are both green I think I need to switch the output state from no to nc or what ever it is now reversed
the motor is turning and because output 2 is also green it is in reverse
No Brains, No Headaches...
jumps4
Post by jumps4 »
Allin1Chris wrote: Wed Sep 25, 2019 11:53 am Also, Do you have your turret wired to output 1? If you force output 2 ON (Green) does your turret then stop spinning?
either or both outputs on will cause the turret to rotate
both on or just output 2 on is reverse
only output 1 on is forward
jumps4
Post by jumps4 »
you said no line under the output is it's normal state
if true my normal state is now green relays on and I need them to be red, relays off
jumps4
Post by jumps4 »
where can i read up on the diagnostic screen
I have inputs 1234 and 7 with line over them, what does that mean?
jumps4
Post by jumps4 »
"CTRL-ALT-F on the same output switches it back to computer control"
they are both green, relays on (no line under output) when I'm not requesting a tool change.
if I leave outputs 1 and 2 in computer control the motor wont stop.
Allin1Chris
PLC Expert
You currently are using the 1 Output only Turret PLC, it is designed for a turret that only moves in 1 direction, which is suppose to be connected to Output 2. Having it connected to Output 1 is going to cause the turret to spin, as Output 1 "NoFaultOut" will stay on (Green) for as long as the control is not in fault.
Your inputs 1234 and 7 have a line over them, as you may have Inverted those inputs. You can do this by pressing ctrl-alt-I on any input to invert the input.
jumps4
Post by jumps4 »
Keith suggested I use the beta one
here is the one I used 4.18 rev1
see wiring diagram. is it the wrong one it shows forward and reverse relays
ACORN_v4.18_Lathe_Turret_Gray_Code_1_Output_Rev1.zip
(354.57 KiB) Downloaded 171 times
hello. yeah. most likely you will need some custom plc programming for that rig.. none of the stock beta plc programs is going to work out of the box with this setup.
PLC programming videos are here.. https://www.youtube.com/playlist?list=P ... i2WKIedQlQ
