Sigh,
Got the Windows 10 upgraded.
Got the centroid 12 upgraded or so I thought.
No real instructions on what to do or not to do that so I just went.
My MP4 probe now does not work correctly.
I was manually touching down to find the top of a piece.
Once the probe touches the little light goes from green to red. All normal.
BUT Now, when it goes touch/red it cannot be moved move back up (z+) via the mpg.
I can move it back up via the control panel
This is not normal.
Just musing. This acts like it does when doing a part setup, Z setting, auto measure.
In that sequence it goes down, touches, stops and sets the part z height.
Ideas?
Probe malfunction after upgrade <resolved>
- CNC Control System Serial Number: 101981
- report_0416151269_2019-08-22_18-11-40.zip
- (329.74 KiB) Downloaded 113 times
Dave Koehler
https://www.koehlerinjection.com
Re: Probe malfunction after upgrade
According to the CNC12 v4.12 release notes:
Does the Z in fact move up when you use the MPG handwheel, but very slowly?Added mpg probe protection. When the probe is tripped, the MPG only works at 1x speeds
It does not move up at all.
I can twirl the knob all day and nothing.
Confirmed via the readout.
Somewhere along the path I did see a probe tripped notice flash by.
it can only be moved up via the panel button Z+ button.
Dave Koehler
Have you tried with the MPG increment set to "x1"? (rather than x10 or x100)
CNC Depot Modular ATC kits
Just did. That allows it to move. Thank youGary Campbell wrote: ↑Fri Aug 23, 2019 7:50 am Have you tried with the MPG increment set to "x1"? (rather than x10 or x100)
I do a lot of poor man cmm measuring with the probe.
I will have to look into turning this safety feature off in case I prefer living on the edge.
Edit:
On reflection I can kind of see how this feature came about.
I had a situation where the Z made a fast uncontrolled move down, destroying the stylus and damaging the probe.
I don't remember the reason for it but I remember that I could not get to the big red button fast enough.
IF this feature can react fast enough that would have saved me a chunk of change.
Thanks Marc and Gary
Dave Koehler
