V 4.18 probing
V 4.18 probing
Updated to 4.18 mechanical touch probe and Tool setter everything is working but it does not disable the spindle and the probe tripped does not stop the movement when jogging with the vcp but it does work when using the mpg
Re: V 4.18 probing
fyi..
Tool setters don't disable the spindle..
Probes do disable the spindle. An input set to "ProbeDetect" will disable the spindle so you don't wrap the touch probe cord up in the spindle by accident.
Spindle inhibit is not on by default for Tooltouchoffdetect as its unnecessary for most applications.
Re: V 4.18 probing
Probe is what I'm talking about looked at my inputs and it sees my probe detect but does not stop movement when is tripped while jogging with the vcp does with mpg and it is not disabling the spindle
Re: V 4.18 probing
post a fresh report.zip for further comments..
Re: V 4.18 probing
Ok will tomorrow afternoon after work not at the shop now thanks
Re: V 4.18 probing
here is my report download/file.php?mode=view&id=6728
- report_780473845840-0206191632_2019-05-21_16-47-25.zip
- (314.4 KiB) Downloaded 167 times
Re: V 4.18 probing
Dholman,
looking at your report file, the probes can't work the way you have configured them.
I guess you meant to configure Input 7 as "ToolTouchOffTriggered" and not "ToolTouchOffDetect". You can't have a detect input without a probe.
-swissi
-swissi
Re: V 4.18 probing
It worked that way before
Re: V 4.18 probing
Just changed it to the triggerd same thing
Re: V 4.18 probing
Just changed input 7 to probe tripped fixed it my bad sorry
