Screw Terminals vs DB25 Header
- CNC Control System Serial Number: haven't installed CNC12 yet
Re: Screw Terminals vs DB25 Header
Out of curiosity, where is parameter 968 and the table for it's values documented? I can't find it in the manual.
Marty, thanks! So, in other words it's kinda undocumented? In the manual, params 900-999 are listed as PLC Program Parameters. BTW, is the same param and setting valid for Mill Pro?
Yes.
It's undocumented, use at your own risk. Anything above 400k requires good wiring practice and a drive that accepts a pulse train over 400k
With so many being recommended to use 100k centroid probably should add that to the 200 and 400kHz options in the wizard.
Its already in the next version
