acorn and dmm dyn 4 losing steps
Plasma CNC Controller: Yes
Re: acorn and dmm dyn 4 losing steps
Did you run the test I had suggested?
If so, what was the outcome?
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Fozzyber,
Your sketch did not upload properly. I will see if I can draw up a quick schematic for you on using those drivers. You do not use the Index signals, those are using when you are using this with encoders. I should have a break at noon today and will make you a quick drawing.
Russ
fozzyber
CNC Control System Serial Number: 985dadec3fe0-0423180848
Post by fozzyber »
uploaded again to see if this one is better
this one seems to work
acorn line device temp.pdf
(601.73 KiB) Downloaded 134 times
cncman172
Post by cncman172 »
This one worked let me review and get back to you shortly.
Russ
cncman172
Post by cncman172 »
fozzyber,
Close but you have a few mistakes.
Diff Driver Pin-6 A+ > DYN4 - Pin-11
Diff Driver Pin-5 A- > DYN4 - Pin-23
Diff Driver Pin-8 B+ > DYN4 - Pin-22
Diff Driver Pin-7 B- > DYN4 - Pin-10
5V needs to hook to the 5V on the Power supply, but it looks like DYN4 might have 5V available at pin-24
The pull up resistors do not attached on the Differential driver outputs, they must be on the Acorn side, pulling up Step-1, Direction-1 up to 24V with a 1K or 2K resistor. You do this on each of the step and direction outputs from Acorn if you are using the Screw terminals. You can avoid the resistors if you use the Step and Direction outputs on the Acorn DB25 connector because they already have build in pull up resistors.
Follow?
By the way a very nice drawing you made... Nice Job
Russ
fozzyber
Post by fozzyber »
drawing rev2
made corrections to the drawing to help others,
let me know if this is good.
seems strange to hook 5V to both sides but I guess it is what it is.
thanks for the compliment.
Jerry
acorn line deviceRev 2.pdf
(608.96 KiB) Downloaded 107 times
fozzyber
Post by fozzyber »
I just realized I might have drawn the pull up resistors wrong. can you double check that.
fozzyber
Post by fozzyber »
ok I think I fixed the pul lup resistors
jerry
acorn line device Rev 3.pdf
(613.32 KiB) Downloaded 99 times
cncman172
Post by cncman172 »
close you did the pull up resistor much closer but they must pull up to 24V on Acorn not 5V like you have them drawn. :)
Russ
fozzyber
Post by fozzyber »
OK edits made, I think we might have a final drawing.
jerry
acorn line device Rev 4.pdf
(603.66 KiB) Downloaded 107 times
