ALLin1DC Current Switch Settings 7&8 <answered>
What is the correct position for switches 7 & 8 on the motor current switch on the AllIn1DC?
Re: ALLin1DC Current Switch Settings 7&8
Tom,
i don't think 7 and 8 are connected to anything, but i've asked chuck to chime in to be sure.
from the allin1dc spec manual.
Centroid_Tech
Post by Centroid_Tech »
Instead of purchasing different types of switches, Centroid used the same 8-pin switches that are used for the limit defeat switches. Since the ALLIN1DC is a 3-axis drive, that means that switches 7 and 8 are not physically connected to anything on the board so it doesn't make a difference what position they are in.
Perfect. Just wanted to be sure - my machine at work had 7&8 off while the new board I just recieved for home had them on.
