I corresponded with Marty tonight on Facebook to find some E-Stop Switches. I found what I needed (thanks, Marty!) and thought I would share my links in case it helps someone else.
Most E-Stop switches I found had one NO switch or one NO and one NC. I needed dual NC. Marty recommended the metal switch assemblies and with these you can swap switch modules.
Here is what I ended up purchasing.
I picked up a few of these 2 for $7
https://www.ebay.com/itm/RED-XB2-BS542- ... 2859657644
For now, I will remove switches from some stops to gang them to get my dual NC E-Stops.
Meanwhile, I will wait for the slow boat from China to deliver these replacement NC Modules. (I may buy some NO modules, too so I can assemble whatever I need)
I purchased Qty 10 of the ZB2-BE102C NC Switch modules
for $10
https://www.ebay.com/itm/10pcs-New-ZB2- ... 1413375497
I hopes this helps someone with their Acorn Setup
Eric
Source for E-Stop (Dual NC Switches)
- CNC Control System Serial Number: 74E1827A5BE2-0905181161
- CNC Control System Serial Number: 0503160222
Re: Source for E-Stop (Dual NC Switches)
Hi Eric
I have used a few of these estop switches with enclosures from automation direct. not as cost effective as the ones you purchased, but if you cannot wait on the slow boat, they have them in stock and you can get them pretty quick
https://www.automationdirect.com/adc/sh ... s-p-230001
this one has one NO and two NC contacts blocks included
they have the contact blocks
