Thanks.eng199 wrote: ↑Mon Jul 09, 2018 2:34 pm The ACORN can take an extremely high encoder frequency. However, there may be filtering added in the future to reduce the frequency to 1 - 5MHz. To maintain future compatibility, it would be best to consider the maximum frequency 1MHz.
The best bet is to follow tblough's advice. Frequencies should be kept as low as possible for best noise immunity and lowest emission. The multiple choices are probably made available so that slower slew rate drivers can be used where higher frequency is not required.
This is incorrect. Quadrature frequency or edge separation is a function of encoder speed. If your A or B channel is not 50% duty cycle at fixed speed, the encoder is bad.DannyB wrote: ↑Thu Jul 05, 2018 7:11 pm It could also be a 100khz input with really fast pulses and a lot of idle time.
(that's why they define it in edge separation time for something like this - the spindle may not be moving at max velocity, but the pulse separation will still be the same whether it's going 1rpm or 10000rpm)
Here is a quick overview of quadrature encoder signals:
https://www.dynapar.com/technology/enco ... e_encoder/
I'm not sure what you think is incorrect - that page, and what you just said, is what i just said (or thought i said).
The pulse length does not depend on the current RPM of your spindle, only on the encoder speed, you just get more or less pulses in the same time interval as the thing moves faster or slower.
https://3l4sbp4ao2771ln0f54chhvm-wpengi ... terval.gif
In any case, doesn't matter (just trying to become less ignorant!), it looks like i should go with the 1us versions
