hom file with output on/off help
mael
Re: hom file with output on/off help
Post by mael »
Hi Scott
Thanks a bunch!
Just to clarify, I cant assign a specific function on the wizard because there is no specific function i want to achieve with the available list. Instead, I keep them at “OUTPUT 3,4 and 5.”
M61 to M68 is a custom (default) macro which i openned and says M94 /61 —-> so /61 correlates to output2 /62 to output2 yes?
Sorry if i made it look like a sounding board. Couldnt help myself to confirm.
Cant wait to test this out in the morning! Thanks scott!
diycncscott
Post by diycncscott »
To use OUTPUT3, OUTPUT4, OUTPUT5 use m63, m64 & m65
use Wizard i/o drop down to select OUTPUT3,4,5, etc.. and then the Macro that turns on output three is automatically assigned to that output. M63 in this example for output3.
mael
Post by mael »
Thank to all who helped!
It works like a charm.
Im now able to home both the slave and main motors using 1 axis port. 4th axis here i come!
