M40 tapping
M40 tapping
Just got a 1989 Atrump bed mill with M40 control . I’m trying to tap with a tension compression tool holder , when programing in Shop floor I Press F3 and fill in all info check F8 and graph shows the tap tapping . But when I run it the program shuts down . I see in the M Series manual that tapping may have been an opposition . If so can I add it now? Thanks for any help ........
Re: M40 tapping
Please email a current report as well as a configuration backup of that system as explained in the CNC7 section of the attached tech bulletin to support@centroidcnc.com. I am assuming that as old as that system is, you are most likely running CNC7 which is a DOS based control. If you are running CNC10 which is a Linux based control, please follow that section of the tech bulletin.
- 193 Generating Report.pdf
- (5.58 KiB) Downloaded 91 times
Re: M40 tapping
Ok thanks I’ll give a try to generate a report and forward to you soon.....
Re: M40 tapping
Ok thanks I’ll give a try to generate a report and forward to you soon.....it is running CNC7
