This checkbox will not be influenced by the PP IMHO.
I have the V2 PP and the latest payed fusion version.
No problems.
Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
Re: Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
1 user liked this post
Well no dice. I have a custom machine built and the community PP. No check box for connecting moves. I loaded a generic machine and PP as well. I still don't have the dialog box. I am running a full version not a hobby version of Fusion.
I have included the material size to display in the graph and RTG for CNC 5.40
Output in the g code:
//stock size output UWE
{ // stock - workpiece
writeComment ("Material Size Min/Max for CNC12 V5.40+ Graphing and Run Time Graphics");
var workpiece = getWorkpiece();
var delta = Vector.diff(workpiece.upper, workpiece.lower);
if (delta.isNonZero()) {
writeln(":::: X- = " + xyzFormat.format(workpiece.lower.x) + (", X+ = ") + xyzFormat.format(workpiece.upper.x));
writeln(":::: Y- = " + xyzFormat.format(workpiece.lower.y) + (", Y+ = ") + xyzFormat.format(workpiece.upper.y));
writeln(":::: Z- = " + xyzFormat.format(workpiece.lower.z) + (", Z+ = ") + xyzFormat.format(workpiece.upper.z));
writeln (" ");
//end of stock size UWE
(File: 1001.nc)
(T3 D=6.000 CR=0.000 - ZMIN=-20.000 - right hand tap)
N10 G90 G94 G17
N15 G21
(Material Size MinMax for CNC12 V5.40 Graphing and Run Time Graphics)
:::: X- = -50.000, X+ = 50.000
:::: Y- = -15.000, Y+ = 15.000
:::: Z- = -20.000, Z+ = 0.000
N20 G28 G91 Z0.000
N25 G90
- centroidForumV3.zip
- (20.3 KiB) Downloaded 23 times
Sorry for the late answer.
Did You select Simulate Connection Moves in the PP also?
New version with the option to post the Material Size or not in a Selection...
- (20.3 KiB) Downloaded 15 times
ooh looking pretty!
