New Build - 'Audit' CNC - Lathe Attachment
It's very difficult to explain what this is. I've just bought 2 of them. One larger than the other. This video shows the unit best ...
These were made by a company and sold under the brand 'Audit'. Effectively its a 2 Axis clamp on Slant Bed lathe attachment meant to fit onto some Triumph / Colchester lathes. The straddle the saddle and then can be moved as needed along the bed. The smaller one I have has 10 inches of Z travel, the larger is 20 inches. I don't know the X distance but its massive.
We believe they were made for the oil industry where threading of long pipes was common place and these were used for a lot of the work.
The engineering that's gone into these is spectacular. They originally ran DC motors with 4.5NM torque. So on the AC servos side, I'd need around 1.5KW for similar performance unless I start to mess with pulleys / gears.
On top of each is a 8 tool Duplomatic ATC.
The weight of each of these is substantial. Even the small one cant be lifted by hand and needs a crane to lift.
I'm hoping I can get this mounted on my Harrison M300 which is starting to show its age and has some wear on the bed / cross slide.
So ye, Acorn or Acorn 6 for feedback .... feels like a waste of 4 axis however ...
The existing DC motors have incremental encoders on them and that would have given the original controls (which stands 6 feet tall) its feedback / control mechanism.
Re: New Build - 'Audit' CNC - Lathe Attachment
Just looking at board options. The tool turret has PNP proximities and also for the angular position feedback. I know with Acorn we cannot read PNP which is a pain and it either needs some trickery or an Eth1616 board.
I'm also concerned about the latency that I saw when I was trying to do my Emco 320, using the Eth1616 board where I was struggling to stop the turret spinning (locking pin engagement) as by the time I saw the bit change, it was too late to fire the pin.
Can Acorn 6 manage PNP directly?
Just checked the documentation, suggests that this is possible. Great.Chaz wrote: ↑Mon Jun 30, 2025 8:30 am Just looking at board options. The tool turret has PNP proximities and also for the angular position feedback. I know with Acorn we cannot read PNP which is a pain and it either needs some trickery or an Eth1616 board.
You may have seen these before - but for the rest of us:
Interesting article on HSM site: https://bbs.homeshopmachinist.net/forum ... attachment
And one for sale up in Scotland. https://www.hibid.co.uk/Audit-CNC-Lathe-attachment/
Thanks. I actually bought these from Kev who was asking, he ended up buying 2 and then kept them a while and never used them. I believe you might know him?Muzzer wrote: ↑Mon Jun 30, 2025 2:59 pm You may have seen these before - but for the rest of us:
The other one I saw too, thanks.
So, managed to get this mounted after a lot of hassle (its made for a larger lathe) and also running.
I am however getting issues with electrical noise. I've traced it to the 9100 series VFD I'm using. I've got 2 more of them, they all do the same. The only way is get it any better is lower the carrier frequency on the VFD which helps a bit. Installed a shield cable to the spindle motor, no improvement, Earthed anything that I could, same.
I'm also getting Ethernet connection warnings which Ive not had before on any build.
Any other ideas other than a better VFD?
I managed to get a replacement VFD from Amazon overnight. Initially saw some noise but then gone. Solved, so I thought.
Now I'm getting creep on the motors when the VFD isnt even running. Not ideal that we cant run full step / direction (both cables) for better noise immunity.
Ive installed the Acorn inside of the Lathe's existing control box. There is little there .... so not sure what could be causing issues. I might move it out and see if that solves problems. The Ethernet warnings are also still there. I am using a shielded cable (the supplied one) so no idea. Ive not had this problem before and have done numerous installs and certainly more challenging install locations.
Things I've tried.
Different Ethernet Cable
Checked drivers, latest installed
Everything apart from power disconnected from the Acorn board, ie, no relay board, no drivers etc
Moved Board onto my workshop floor, everything apart from power disconnected
Still getting Eth errors and fails the comms test.
Other than a new PC to try, anything else I can do?
Related reading:
viewtopic.php?p=65526&hilit=network+adapter#p65526
try other settings on the network adapter.
Ive moved over to another PC, no errors. Oddly, both running version 5.30 yet one wanted a firmware change. So there might be subtle differences. Thanks, had considered changing from auto to fixed etc. In the networking world this was a very common fix years ago.
That said, I'm still getting some creep on the drivers. Never seen this before (even without it being connected to Centroid), so something else going on.
