M297 and M298 (503 Invalid M function)
Ryan Patterson
Post by Ryan Patterson »
When trying to use M297 I get a 503 Invalid M function. I need to disable the soft limits.
Centroid_Jacob
Web Developer
Re: M297 and M298 (503 Invalid M function)
Post by Centroid_Jacob »
Hi Ryan,
Please post a report. Here's how:
What version of CNC12 are you running?
If I remember correctly M297/M298 were added in v5.24, so if you are on an older version then the 503 error makes sense.
When requesting support please read this post first.
A fresh report makes it easier to assist you. To make a report check this post
CentroidFrog
Tech Support
Post by CentroidFrog »
Jacob is correct, M297 and M298 were added in CNC12 v5.24
CNC12 v5.30 is available here: https://www.centroidcnc.com/centroid_di ... loads.html
As well as upgrade and installation instruction, which I'd highly recommend following:
https://www.centroidcnc.com/centroid_di ... ctions.pdf
