Hello,
I am trying to modify the PLC program on my Acorn lathe. I would like to change the logic of the Shuttle Express device, so that when selecting an axis, it only chooses between axis 1 and axis 2, and skips over axis 3 and axis 4. I assume I can remark out the necessary lines to accomplish this.
I have read the PLC manual and watched some videos. In the manual is says to compile the source code, you use a program in the cncm or cnct folder that is called mpucomp.exe. I have searched in all my folders and I can't find that program.
What am I doing wrong? Do I need to edit the acorn_universal_template.src file, and then run the wizard to compile it?
Any help would be much appreciated.
If a Centorid Tech can easily remark out the necessary lines and compile it for me, that would be great.
Thanks for your help.
Mike
Can't find mpucomp.exe
- CNC Control System Serial Number: 0479B7ADF2F3-1127192707
- Tech Support
Re: Can't find mpucomp.exe
On page 13 of the PLC programming manual you will find information on how to compile a PLC program using the command prompt:
https://www.centroidcnc.com/centroid_di ... df#page=13
First, change to the cncm directory in the command prompt:
Next, compile the PLC program:
Compiling the PLC program can also be done using Notepad++, which I'd highly recommend using if you're not.
Information on configuring Notepad++ can be found in tech bulletin 294:
https://www.centroidcnc.com/dealersuppo ... ds/294.pdf
cd \cncm
mpucomp your_plc_program.src mpu.plc
So there is no stand alone executable program called mpucomp.exe? I haven't tried anything yet, I was just confused because I couldn't find a program with that name.
Thanks!
Mike
Thanks!
Mike
Sure it is in the cncm folder.
If not you have deleted it.
Thanks Uwe. I'm really confused now. I checked the cnct folder on the lathe that I am building now, and mpucomp.exe is there. But when I look at the cncm folders I have backed up on my thumbdrive from my milling machine, both 4.2 and 5.3; neither one has the mpucomp.exe file.
When I backed them up onto the thumbdrive, I just copied the main cncm folders.
This is very odd. But at least the issue is resolved. Thanks again.
Mike
Mike
