x-x+ jogging moves in the same direction in the x- direction <resovled>
Re: x-x+ jogging moves in the same direction in the x- direction
sorry for the screen shots snip wasn't working
got the boar from centroid website
thanks, i have that info from the report.zip
what i was asking for is screen shots from the clearpath software setup screen for each axis.
use the windows snipping tool. ,type 'snip" in the windows search to find it
First, make sure your wiring is OK. Then move X over to the 4th axis on Acorn and assign the 4th axis in the Wizard to X and see if your axis starts behaving.
When did you buy the board?
moved x wiring over to 4th axis would not allow me to name it x but called it a axis and it works as should looks like I have lost x axis or #1 axis do you happen to know if I can change anything else to get it to read x and not a
for now it will only be a 3 axis mill?
Did you change it from a rotary axis to a linear axis?mccue.sc wrote: ↑Wed Jan 25, 2023 9:41 pm moved x wiring over to 4th axis would not allow me to name it x but called it a axis and it works as should looks like I have lost x axis or #1 axis do you happen to know if I can change anything else to get it to read x and not a
- CNC Control System Serial Number: 6679
Possibly one of the cables got nicked/cut when running them through the bulkhead and is now shorting out somehow? Just a wild guess but these things happen.
