Gremlins
Gmachine
CNC Control System Serial Number: E415F6F6E589-0410203112
Re: Gremlins
Post by Gmachine »
Sorry for the delay. Here is a resent video on YouTube with the issues. Now it is in the x and y axis. The only way I can describe the problem is that it is losing steps. The problem is coming and going in all the drives and showed up right after I updated the software to CNC12 v4.64.
I also attached all the reports I did that correspond to the video time stamps to this post.
Any help would be greatly appreciated.
Have a good Memorial day.
report_E415F6F6E589-0410203112_2021-05-29_12-09-51.zip
(611.63 KiB) Downloaded 77 times
report_E415F6F6E589-0410203112_2021-05-29_12-09-44.zip
(615.09 KiB) Downloaded 74 times
report_E415F6F6E589-0410203112_2021-05-29_12-03-17.zip
(615.09 KiB) Downloaded 67 times
report_E415F6F6E589-0410203112_2021-05-29_11-52-55.zip
(611.81 KiB) Downloaded 78 times
report_E415F6F6E589-0410203112_2021-05-29_11-51-54.zip
(614.03 KiB) Downloaded 73 times
report_E415F6F6E589-0410203112_2021-05-29_11-48-49.zip
(611.92 KiB) Downloaded 71 times
report_E415F6F6E589-0410203112_2021-05-29_11-46-44.zip
(623.98 KiB) Downloaded 72 times
Re: Gremlins
No need to post all the reports. Only a fresh one and maybe one from the previous version.
Did you do a FRESH install and hand copy in all your machine settings or did you restore from an older report?
Gmachine
Re: Gremlins
Post by Gmachine »
After not finding anything wrong with my connections or wiring I moved forward with wiping cnc 12 and starting over with fresh install. Immediately after the installation and rehoming the machine I could tell it was working properly. I ran my machine for 4 hours on 6/19/21 with not problems. My guess is that a file was corrupted during installation causing my issues. In the future if someone has issues after an update. Tell them to reinstall the software before jumping to conclusions.
Re: Gremlins
Gmachine wrote: Sun Jun 20, 2021 8:17 am After not finding anything wrong with my connections or wiring I moved forward with wiping cnc 12 and starting over with fresh install. Immediately after the installation and rehoming the machine I could tell it was working properly. I ran my machine for 4 hours on 6/19/21 with not problems. My guess is that a file was corrupted during installation causing my issues. In the future if someone has issues after an update. Tell them to reinstall the software before jumping to conclusions.
I recommend starting with a fresh cleaning install, using Wizard screen shots from the last installation. NOT using Restore Report from an older version if you are having trouble.
I hope your fresh install has helped
