The DMM servos have arrived, was looking at Martys video he is doing a router. I see he is waiting for the wiring for the DYN4 drives, is the wiring on here not correct?
Got 1.5KW servos for a Bridgeport clone mill. Hope there strong enough.
DMM Servos and DYN 4 drives have arrived
- CNC Control System Serial Number: 0216041209
Barnesville, PA.
Re: DMM Servos and DYN 4 drives have arrived
1.5kw servos are more than enough.
I'm running the 750w servos at 2:1 and can get 330 ipm running them on 120vac.
EDIT: I linked to the DYN2 schematic originally.
There is an issue with the schematic. Not that it will damage anything, but DMM has recommended using an external 5volt supply instead of the internal supply. It causes noise issues, and I can confirm that is the case.
This schematic works: download/file.php?id=1567
Clay
Clay
near Winston-Salem, NC
Thanks Clay, will have to run and get an external 5V supply. Last evening 11 pm 64 degrees and raining. 8 am 9 degrees truck doors frozen shut.
Barnesville, PA.
Sounds like the same weather we had the night before. Where do you live?
750w @ 2:1, 330 ipm...sounds like you're building a log splitter!
Milton in Collierville, TN
Was that meant for me?
Try doing some rapids at 330 ipm on a Bridgeport series1. Seems like it's plenty fast to me.... But then again I'm a cnc newbie.
