Now Available.
https://shopcentroidcnc.com/shop/cnc-ex ... out-board/
The AcornSix Differential Drive Interface board provides six drive axes of RS422 compatible differential drive output signals as well as 4 additional Scout RJ45 expansion ports. The D-Scout board is commonly used when AC servos drives are being employed with the AcornSix to make use of the superior quadrature step and direction signal communication protocol that the D-Scout board provides. The additional Scout ports facilitate easy connections with a common shielded Ethernet cable to any Centroid Scout communication protocol equipped product such as the PLCEXP1616 (#14575), Scout Operators Control Panel (#14612) and the Encoder-Scale Input board (#15330).
Plugs directly into the AcornSix motherboard.
Now Available: AcornSix Differential Drive Interface board
Re: Now Available: AcornSix Differential Drive Interface board
Is there a schematic on this board yet on the Centroid website?
Also, is the Acorn6 going to change any when the Plasma part is added to it in the future?
Hi,
i should have a spec manual and example connections schematic up on the web soon.
no hardware changes are needed to AcornSix for Plasma use. (what did you have in mind?)
Link to typical AcornSix with D-Scout to Yaskawa connections.
https://www.centroidcnc.com/dealersuppo ... 230.r1.pdf
