alarm 916
- CNC Control System Serial Number: 0615050824
alarm 916
Anytime i use the MDI I get this fault can you help me?
- report.zip
- (63.36 KiB) Downloaded 98 times
Re: alarm 916
It says your estop is pressed.........................
Re: alarm 916
The picture is just for the serial number I can run programs with no problem just when I try to use the MDI I to make a move to re zero I get this fault
Re: alarm 916
It's most likely because parameter 11 is set to -14 rather than 14. From the main screen press F1(Setup)->F3(Config)->default password is 137->F3(Params). Change the value of parameter 11 and press F10(Save). See if that helps you out.
Re: alarm 916
Parameter 11 is set to -14 rather than 14 ??
Re: alarm 916
Nevermind normally open normally closed I read the manual thanks for the quick reply
