mpu11 and sd drives
Posted: Tue Jun 22, 2010 7:47 pm
by 77randyc
Is the mpu11 compatable with Centroids "SD" ac Drives. The mpu11 seems to have only 6 fiber optics while the cpu10 board uses 7.
Also does the cnc11 software work with the "SD" drives. The demo copy i have does not have an ac drive menu to set up ac drives,(CNC9.hex file).
Randy
Re: mpu11 and sd drives
Posted: Wed Jun 23, 2010 7:23 am
by diycncscott
Randy,
The MPU11 does not currently support the Centroid SD drives. Other than to say that it has been discussed and that support may be added in the future, I can't give you a timeline or say with any certaintly that support for the SD drives will be added.
Posted: Wed Jun 23, 2010 4:30 pm
by 77randyc
Scott,
Thanks for the reply.
One more question on this subject, using a three axis mill w/rotory tilt table for 5axis how much faster/better would a system using CNC10 board and sd3/sd1 w/ 1kw ac servos
be compaired to a system using mpu11 board and DC1 w/ 29inlb (or 40inlb) dc servos on the same machine.
Thanks for your input:
Randy
