With new software releases now provided as monolithic *.exe files, is there any place we can find the mpuplcprograms directory tree?
Suppose, for example, that I want to compare the latest Allin1DC standard lathe PLC program source with the latest Allin1DC Hardinge-specific lathe PLC program source. Where do I find those two files, without running the full-blown installer twice onto my computer?
PLC Installer, mpuplcprograms directory
Re: PLC Installer, mpuplcprograms directory
Marc, the exe installer can be opened and browsed with 7-Zip. I'm not sure if it's actually a zip file or if 7-Zip just knows how to read Windows installers. At any rate you can open it with 7-Zip and drag and drop the mpuplcprograms directory any where you want it.
I’ll keep an eye on this thread
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Thanks Tom, that worked nicely.
The mpuplcprograms directory tree is installed in C:\Program Files (x86)\Centroid\mpuplcprograms
It gets deleted and recreated every time the installer is run to ensure the plcs are up to date with that version.
Marc wanted to have access to the latest PLC programs WITHOUT having to run the installer. This is useful when trying to find changes made to a modified PLC, or just seeing what updates have been made between Centroid stock PLC releases.
This is good to know too, though. I usually do have a recent CNC12 installed on this computer. I just didn't want to have to overwrite that installation repeatedly just to get a look at a different PLC program source.ASPeters wrote:The mpuplcprograms directory tree is installed in C:\Program Files (x86)\Centroid\mpuplcprograms
Both methods will prove useful.
