Lathe Sauter Turret ATC needs more I/O for control
kenmwallace
CNC Control System Serial Number: C143471
Post by kenmwallace »
My 18" Chevallier is making parts under Acorn control now.
However, I am changing the turret position manually.
The Turret software that is built into the CNC12 appears to lack two control features I need.
My turret has a solenoid that drives a locking pin into the rotating part to hold it while the motor reverses to lock the turret position.
The locking pin position is sensed by a prox sensor. This tells the control that the motor can be reversed for locking.
So, I need to add these functions to the existing program that reads the position code and runs the motor CW or CCW.
Before I study diving into the source code, has anyone already done this?
The Sauter type number is: 0.5.480.514 8 positions.
Ken Wallace
San Diego, CA
Re: Lathe Sauter Turret ATC needs more I/O for control
i moved this post to the Acorn forum
Please start a photo album of your machine with lots of photos so we can see what you see.
the Centroid Acorn Wizard has pre programmed Lathe Turret setups that can be used as is or customized to fit a turret application that is not supported by any of the typical methods use. an overview of what is included with the Wizard is here.
https://www.centroidcnc.com/centroid_di ... _guide.pdf
