Getting M56 working after update
vw_chuck
CNC Control System Serial Number: 0035FF8FEB5F-0708203490
Post by vw_chuck »
I updated to version 5.08 and I am having trouble getting the M56 button working on my lathe.
I changed the tailstock in and out to M56 on the VCP I am using
I got M55 working by copying the Mfunc55 from my version 4.5.
I tried to get M56 working by copying Mfunc56 from my old version but when I push it is goes to chamfer one shot. I looked in the button folder and M56 and the chamfer one shot are both skin event 19.
I followed along in the VCP manual but there was no mention of a skin event. No idea what a skin event is and not sure what I am doing wrong.
I attached my report if that will help?
report_0035FF8FEB5F-0708203490_2024-01-24_18-14-41.zip
(860.75 KiB) Downloaded 21 times
vw_chuck
Re: Getting M56 working after update
Post by vw_chuck »
Looking at the skin events from the acorn_lathe_plc skin event 19 and 70 are linked to row 3 column 5. Also the one shot for chamfering is linked to skin event 19....something seems wrong here as the one shot for chamfer is not at row 3 column 5?
Centroid_Tech2
Post by Centroid_Tech2 »
In CNC12, change machine parameter 198 to "5611".
vw_chuck
Post by vw_chuck »
Will the one shot chamfer still work? Will the M56 button work? I want them both to work.
I will try this when I get home tonight.\
vw_chuck
Post by vw_chuck »
OK I changed this to 5611 but now the one shot for chamfering also does the same thing that my M56 button is programmed for. How do I get the one shot chamfer working again?
vw_chuck
Post by vw_chuck »
Can I repurpose another button like chuck open or chuck close since I don't use that? Is there a diagram of what AUX outputs are used where on the lathe VCP?
vw_chuck wrote: Fri Jan 26, 2024 12:24 pm Can I repurpose another button like chuck open or chuck close since I don't use that? Is there a diagram of what AUX outputs are used where on the lathe VCP?
Yes, see
