Drive Fault Error 9031
JerryLouisMartin
CNC Control System Serial Number: E8EB1128AAC4-0405180824
Post by JerryLouisMartin »
I turned on my CNC this morning, I received a 9031 error immediately upon clearing and trying to home.
Running the Lathe Pro 5.06 Version.
Tried restarting and clearing error and received it multiple times.
Lossed as to the cause and the fix?
Board went bad?
Software corruption?
Any help or ideas would be greatly appreciated!
Re: Drive Fault Error 9031
9031 Drive Fault error is when one drive is in ALM, Drive OK input is set.
Check the input assigned to Drive Ok
JerryLouisMartin
Thanks for the assist!
Steel_player@1
CNC Control System Serial Number: 98F07B461D8E-0601226262
Post by Steel_player@1 »
My Mill has been occasionally going to a 9031 fault after I would home the machine and start to use it again, however today it would not jog away from home using the XY, or Z axis. Every time I would reset and try to move any of the axis the 9031 fault would occur. Automation Tecnology built this controller for me using Centroid Acorn a little over a year ago and it has been working great until the last few days. What do I need to do to find this fault and fix it?
James
