Adding a tool height pad
RGSparber
CNC Control System Serial Number: 38D269533454-0111180523
Re: Adding a tool height pad
Post by RGSparber »
cnckeith wrote: Tue Aug 29, 2017 10:57 am wire the probe according to the schematic and it works.
I am running Legacy and the corresponding schematic doesn't seem to mention a TT port. Did I miss it?
Rick
please see the Tool Touch Off schematic i attached (S14822) in my previous post. and connect the tool touch off device as shown. Probe trigger connects to input 7 (and if you are using it probe detect connects to input 6 and set accordingly with wizard.) and then use the wizard to set input 7 to "Probe Tripped" and press write to cnc control configuration as shown in previous post and you will be good to go. updated legacy schematic attached as well.
S14834-ACORN TO GECKO G540 WITH STOCK DB25 CONNECTIONS Legacy.pdf
(88.13 KiB) Downloaded 189 times
RGSparber
Post by RGSparber »
OK, ready for the experts to review:
http://rick.sparber.org/TTCA.pdf
Rick
Thanks for the great explanation Keith!
I noted probe input detect is such a simple circuit. It just closes the circuit at the probe done by a "stereo" jack. When the input jack is pushed into the probe a circuit closes and tells the control a probe is being used and NOT to let the spindle turn on (if controlled by Acorn) A simple and excellent safety feature and should be used. (Beevo, your probe wouldn't have gone flying ;) )
