So ive just built a rotery 4th axis using another clearpath servo and all works well very happy with it.
My problem is i use fuson 360 for CAD/CAM and post with the centroid post Processor.
I went into the post code and changed the ( if false ) to ( if true ) to enabled the 4th A axis all working fine.
Run my 1st part and hit a massive problem.
When my spindle turns off for its 1st tool change it wont start back up. The relays no longer click To turn the VFD on.
Even if i shut down CNC12 and restart then turn off auto spindle and try and start it i get nothing.
Its like the micro controler has a fault.
If i shut down CNC 12 and power off my acorn bord and then start it back up the spindle will work again untill a tool change is needed and then stops and wont respond again on my program
I run a 3axis program to check and its fine can start stop the spindle on tool changes and doesnt ever cause a problem.
Can anyone help out.
Im on CNC12 4.80 and its been 100% Reliable so dont wamt to upset my luck lol
Shoud i try upgrading to 5.08
What am i missing to have the spindle become Unresponsive.
Many thanks
Ash
