Paired axis / homing switch issues
Insect
Post by Insect »
The system is pretty much operational, but.
When I set up homing as "manually square gantry" it homes fine, but naturally does not fine-home the squareness each time.\
When I set it to 'automatic square gantry' it removes some of the controls to set the limit switches that govern this.
I attached a report and screenshots. When attempted, the auto-program shows an issue (screenshot).
My homing switches are set to be green, per directions.
Can you guide me?
report_0008DC111213-0605230121_2023-10-30_15-31-42.zip
(839.4 KiB) Downloaded 3 times
Insect
Re: Paired axis / homing switch issues
Post by Insect »
Problem resolved, SlavedHome input needed for Axis #4, per the Centroid tutorial on paired homing
kb58
Post by kb58 »
Can you guys who find a solution please post links to these enlightening tutorials. Yes, I know they're all in that big list but since you found it directly, a direct link would be appreciated for us noobs.
Oh, and edit the title of the first post, adding "- resolved" to the end of it? Thanks!
Previous hobby, building hard core sports cars. See http://midlana.com/ and http://kimini.com/
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
kb58
Post by kb58 »
Thank you, sir! I knew of one document from Centroid on the topic but not this one.
