Touch Screen Monitors
JRD56
CNC Control System Serial Number: None
Re: Touch Screen Monitors
Post by JRD56 »
I recently purchased an Acer UT222Q at Micro Center for $249. At 22" its a little larger than I really wanted for my little bench top mill but I can live with it. I connected it via Display Port and could not get the touch screen functionality to work. I've since learned you need the USB connection also. I guess that makes sense in that the Display Port likely just sends data out, not in. The documentation from Acer is really lacking. All in all I'm very happy with it, but I'm only in bench test mode so far.
Just FYI, the Viewsonic TD2210 will be back in stock hopefully by the end of November so I am told by Viewsonic. It has not been discontinued. Victim of the chip shortages.
Emzy cnc
Post by Emzy cnc »
Do it vertical... much batter :)
Proidea
Post by Proidea »
Hi, good job: this is what I'd like to do. Could you please share something more?
Henry
Muzzer
Post by Muzzer »
I recently bought a Hanspree touchscreen. Very nice, works fine.
https://www.hannspree.eu/product/ht-225-hpb/
I'm actually using it with LinuxCNC but it would work nicely with Windows / CNC12. It uses a capacitive touch system - the Viewsonic seems to use the IR (light) system which I found to be easily upset by direct sunlight and dust. In the end I disabled the IR touch feature and now just use CNC12 with a mouse. Personally, I'd recommend either capacitive or resistive, not IR.
Sword
Post by Sword »
That looks like a clone of the Planar Helium PCT2235, or vice versa. I got mine in 08/10/2020 for $180, now it's $306! :shock:
Scott
One of my favorites. Because it uses resistive technology, better than capacitive, its also a low end commercial Touchscreen.
Refurbs have been good:
ViewSonic TD2210 22 Inch 1080p Single Point Resistive Touch Screen Monitor with DVI and VGA, Black (Renewed)
by DealParade
Learn more:
Muzzer
Post by Muzzer »
Marty - the Viewsonic touchscreens I'm seeing currently seem to be based on IR sensors. Do they still make the resistive ones you refer to? I couldn't see any.
https://www.viewsonic.com/uk/products/lcd/TD2223
Muzzer wrote: Tue Dec 28, 2021 7:03 am Marty - the Viewsonic touchscreens I'm seeing currently seem to be based on IR sensors. Do they still make the resistive ones you refer to? I couldn't see any.
The link I posted from Amazon (US) are the resistive monitors. They still make them, they had a chip shortage that was affecting supply. They had hoped to have them back in stock at some of their resellers by now. (I spoke with their sales team) I thought it was discontinue so I reached out.
TD2210 is a good monitor. Gary turned me on to it some time ago.
ThinkCentre M900z All-in-One
Dont know what type of touchscreen it has, but works fine even wit some dust on it
