6-Axis Lathe and Mill combined - what is possible ?
RC-Lights
CNC Control System Serial Number: 0008DC111213-1005220061
Post by RC-Lights »
hi all,
let me quickly introduce me and my project.
my Name is Michael, i am from Germany and my plan is to build a CNC-Lathe from Scratch. The well known user "suntravel" convinced me, that Acorn is the best Hardware / Software combination for that ;)
i am a mechanical Engineer with a workshop of manual machines like a lathe, mill and a small cnc router for wood, etc. And the next step is having a CNC Lathe, most of my parts are round. For me it is really annoing to machine parts on the lathe and when i need a milling operation on it, i have to go to my mill with rotary table and than i have issues with the runout. So why not combine a lathe with a milling axis ?
and Uwe aka "suntravel" showed perfect, that this is possible. So i started planning over a year ago und changes the concept several times. but now, the concept of the lathe is fixed and i started with the build some weeks ago.
here a a picture of the lathe-part of the machine:
So far so good. The mechanical part is clear, i did a benchtest with the acorn six controller and the drives, and i am pretty sure, the system will run. I have some concerns how to integrate the ATC turret, but maybe i can realise that as well. As a first step i will start with a manual toolchange with the multifix system.
But you see, i have a second Z axis on the machinebed. Here i want to implement a tailstock for turning long parts or have a long drill, which could make trouble on the turret. but i have more ideas about that, maybe it is possible to integrate the milling spindle here with 2 addional axis.
so i planned in CAD and from mechanical side it should work.
but i have some concerns, how i can controll all of the axis.
my ideas:
-lathe operations should be clear, can be done by intercon or per CAM, some tailstock action or drills in tailstock can be added in G-Code direct on maschine.
-some easy mill operations can be done also with G-Code after turning.
if this works, that would make me very happy, everything which comes now, would be a dream, but maybe it is possible.
i know, there is a Fusion Cam Postprocessor for mill operations on a lathe, but i am not sure, if i can use it, because my milling spindle would be on a different Z and X axis, so Z2 and X2. maybe i can modify the postprocessor, but not sure, if that is that easy. probably not.
different scenario: I plan also with a brake on main spindle for indexing and milling, so maybe it is possible to use the C-Axis with X2, Y and Z2-Axis as a pure mill, without some lathe operation. here is also my question, if this could be possible.
i have basic knowledge in coding, but i am far away from calling me an expert in that.
i also know, that is a really long way, not sure, if it will work anyway. but i would like to try it.
would be very happy if i can get some feedback from your side.
some more information about the the machine and the components i use:
-I buyed a very massive Weiler Headstock on Ebay with a center bore of 45mm and around 100kg of weight, perfect base for the lathe.
-the machine bed is a 500kg tooling plate from a huge mill, 1200x700x200mm, will be build in vertical orientation for good chip management
-Spindle motor will be a 4KW Servo with 1:2 belt ratio for around 3000 RPM on the Spindle
-Axis Servos are JMC AC Servos with 750W and brake for the vertical Axis
-Linear Rails are Hiwin and THK in Size 30 and 25,
-Ball Screws TBI Motion with double Nut, grinded, C5.
-all of the crossslides and plates will be out of steel, no aluminium at all.
-package protection for linear scale at least on the lathe axis, maybe also on the mill axis with Acorn Encoder Expansion Board
Encoder on Main Spindle
-Brake disk on main Spindle
-i have also allready the milling spindle, it is driven tool from a Traub Servo Turret with Sanvik Capto 3 Interface, really nice for tool quick change. i can easily adapt a Servo Motor and have a compact milling spindle.
Total weight is assumed to be around 1300kg.
hopefully we can have a good discussion about the project. I know, i am just at the beginning. It will be a long way and it will be expensive, but i am sure that i will finish that thing ;)
Thank you very much in advance,
best regards,
Michael
Re: 6-Axis Lathe and Mill combined - what is possible ?
Hi Michael,
should be no problem to run this with Acorn6 lathe ultimate.
The Mill/Turn PP for fusion I am using can be modified to use other axis labels for milling.
RC-Lights
Post by RC-Lights »
hi Uwe, thank you for the answer.
give me a good feeling to design the milling axis with more effort for better results.
But will it be possible to have probing etc for the milling tools ? And all of the milling intercon functions will not work, right ?
here is a quick demonstration, how the axis movements will be.
RC-Lights wrote: Tue Oct 03, 2023 5:00 am hi Uwe, thank you for the answer.
RTG will not work, it is only 2D for turning. Tool Lib and touch off will not work also with other axis labels than X Z, but you can use other WCS to save the position for different mills.
Intercon is also only for turning, if I make parts with milling, I use Intercon for turning and handcode milling in the g-code from Intercon, or I do the complete part in fusion with the PP I made for mill turning on my lathe.
RC-Lights
Post by RC-Lights »
Hi Uwe, that is my understanding also, but good to get in confirmed.
