AcornSix - Lathe Retrofit (DC Servo Motors)
Posted: Tue Sep 26, 2023 9:55 am
Hello everyone,
I'm currently finishing a 3 axis mill retrofit with the ALLIN1DC controller and for now, quite happy with the results. The reason I went on that route was because one of the drivers was damage. I still manage to use the original spindle driver.
I'm looking to do the same to a small slant bed lathe, but this time, the machine is in operating conditions, with no faults, just an old 90's interface. Since the mill is working with Centroid, why not the lathe as well.
That is why I'm posting on this board, the AcornSix has a few features that could make it work. The X and Y axis are driven by tachogenerator DC motors with +/-10v input at the driver. The same happens with the spindle driver, it is also a DC motor and driver also expects +/-10v. Will the AcornSix enable me to use the original drivers with 3 analogue +/-10v outputs? I could then use some feedback with encoders at the ballscrew just like the original machine was design.
Can you please let me know if AcornSix can be programmed to enable such features?
Thanks in advance,
Cheers
Thanks in advance,
Cheers
