Page 1 of 3
WMPG-4 pendant only works at 1x, but not 10x nor 100x
Posted: Mon Sep 11, 2023 10:25 pm
by sakumar
After upgrading to CNC12 v5.06 my pendant only works at 1x (for all 3 axes).
For the other speeds it doesn't move at all.
Is there some new configuration that I missed? What should I look out for?
Re: WMPG-4 pendant only works at 1x, but not 10x nor 100x
Posted: Mon Sep 11, 2023 11:42 pm
by tblough
Usually this is due to the control thinking the pribe is tripped. If you will post a report from your machine, that will provide more information for us to help you with.
Posted: Tue Sep 12, 2023 10:51 am
by VeroEng
Same problem for me (and other issues) since upgrading to 5.06.
Posted: Tue Sep 12, 2023 2:35 pm
by sakumar
The report is attached above. Thanks.
I do have a KP-3 probe configured, but it was not connected when I tried to use the pendent. I connected it, and toggled it. The triggered / un-triggered messages appeared on the screen, but it didn't fix the issue of the jog speeds > 1.
Posted: Tue Sep 12, 2023 2:50 pm
by CNCMaryland
When you use probe detect, this is the case. You should be able to click the x10 x100 afterwards of plugging in the probe.
Posted: Tue Sep 12, 2023 8:40 pm
by sakumar
CNCMaryland wrote: ↑Tue Sep 12, 2023 2:50 pm
Thanks! Some progress to report. If the probe is left plugged in, then the jogging works normally. But it stops working at 10x and 100x if the probe is then disconnected.
I don't want to have the probe plugged in the entire time. How to fix that?
Posted: Tue Sep 12, 2023 9:06 pm
by sakumar
OK -- I can see how this is a safety feature -- probe unplugged means 'tripped' so it doesn't allow fast jogging to prevent the probe tip from getting broken. Can I disable this feature?
Posted: Tue Sep 12, 2023 10:01 pm
by Gary Campbell
Reverse the logic on the probe detect input
Posted: Sun Oct 15, 2023 6:16 pm
by TravisR100
Was this issue ever solved? I'm having the same problem.
Posted: Mon Oct 16, 2023 11:27 am
by centroid467
TravisR100 wrote: ↑Sun Oct 15, 2023 6:16 pm
It sounds like the logic is reversed on probe detect input for the others. Have you checked that on your system? Please post a report so we can see what is going on.
