Posts: 3457 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Fri May 02, 2025 1:31 pm
midy wrote: ↑ Fri May 02, 2025 9:54 am
Thanks Tom, im taklking about page 8 has this statement:
3.) For Acorn/AcornSix/Hickory systems or if you do not plan on compiling the PLC with Notepad++,
then skip to Step 12.
Does that mean if you have acorn you skip to step 12? Thats how it seems to read to me?
This means if you want to compile a PLC ( this is what you want ) do not skip, follow the TB on all steps, easy peasy.
This really is the easy part, understanding the PLC logic is another thing, something why I have grey hairs now
midy
Posts: 293 Joined: Wed Oct 11, 2017 12:20 pm
Post
by midy » Sun May 04, 2025 9:29 am
Well I think i'm nearly there, just one last speed bump I hope. NP++ says it can't find the file but the files are in the cncm folder?
Post
by suntravel » Sun May 04, 2025 10:40 am
Wrong filename for a lathe, you want to compile acorn_lathe_plc.src
midy
Post
by midy » Sun May 04, 2025 10:42 am
No. I am doing the mill aswell. This is correct.
This the mill cncm directory
Post
by suntravel » Sun May 04, 2025 4:45 pm
Do you have the compile.cmd in the cncm folder?
midy
Post
by midy » Mon May 05, 2025 11:42 am
I do yes. I did as instructions said and compile mill.txt in the cncm folder and changed it's name to compile.cmd. I assumed you overwrite the existing compile.cmd file?
Post
by suntravel » Mon May 05, 2025 12:28 pm
compile.cmd is installed automatic when installing CNC12, but you can also use the file in the NP++Zip and just rename like in the TB.
Pls. post a fresh report.
midy
Post
by midy » Fri May 09, 2025 9:21 am
thanks for looking, i still have not figured how to compile?
report_98F07B923769-0307236872_2025-05-09_15-15-21.zip
(1014.43 KiB) Downloaded 5 times
Post
by suntravel » Fri May 09, 2025 9:32 am
Report is from the mill and no compile.cmd in the cncm folder.
The error in Np++ is telling you it can not find this file, because it is not there....
midy
Post
by midy » Fri May 09, 2025 10:31 am
Ive just realized that i need to do the latest update, so will come back to this on a fresh cnc12 install
