Hi, This may be an 'out in left field' question, but is there way to reverse the dial direction on the Ajax supplied MPG.
My Bridgeport S2I2 has jog sticks and a matching MPG that mimic table movement rather than head movement. The MPG of which to be replaced by the Ajax 100-step MPG. However the old MPG and new one rotate in opposite direction to achieve +/- movement. I'd like to reverse the direction on the 100-step to keep it matched to the original MPG. Is this a software change, or something like a A/A' B/B' swap?
Jay
100 Step MPG - reverse dial direction
- CNC Control System Serial Number: A900438
Okotoks, Alberta
Re: 100 Step MPG - reverse dial direction
Jay,
Unfortunately, there isn't anything that can be done in the CNC software to reverse the direction of the MPG encoder signals. You will have to physically swap the A signal with the B signal and the /A signal with the /B signal.
Thanks, I'll give the A>B and A/->B/ swap a try see how it works.
Jay
Jay
Okotoks, Alberta
Whoop's!
..just noticed the new Allin1dc manual shows two different ways to wire up the MGP - check out the A/A+/B/B+ connector pin locations on page ~115 ( the ALLINONEDC Cables Schematic) - then compare it to the ALLINONEDC Connectors on page ~139
so.. which is the right way - so I can reverse it for my application.
Jay
Jay
Okotoks, Alberta
I am a little confused. Attached are the photos from pages 115 and 139 of the ALLIN1DC installation manual and the encoder pinout on both pages are exactly the same. The only difference is that on one page the signal's compliment is designated with a backwards slash, \, while on the other page it is designated with a dash, -. Please clarify where you are seeing the signal incompatibility.
- ALLIN1DC Encoder Pinout.docx
- (141.18 KiB) Downloaded 84 times
Yeah - the pages numbers were confusing. I was using the pages numbers from the PDF Reader, rather than the doc directly.
Here's the screen shots
Okotoks, Alberta
I apologize. I was looking into the encoder signals rather than the MPG encoder signals. The signals on the ALLIN1DC board layout are the correct signals. Pin 1 of the MPG connector starts with +B then -B then +A then -A.
Awesome! - thanks for the clarification!
Jay
Jay
Okotoks, Alberta
