Everything was working fine until I turned on the spindle board and the pwm connector started smoking and flashing. I had the PWM installed to the pwm2 pins. I had this same board working with the Acorn it should have worked with the AcornSix.
It has a error 6 but goes away. I can communicate with it but steppers don't move now. My System ID is 0008DC111213-0605230122.
AcornSix Board Bad
AcornSix Board Bad
- report_0008DC111213-0605230122_2023-07-29_18-03-46.zip
- (801.42 KiB) Downloaded 1 time
Re: AcornSix Board Bad
looks like power got connected to the wrong place. email support@centroidcnc.com and ask for RMA to return it for repair.
