H7 pinout for Rev 3. Upgrading to Rev 4 and new Relay PCB
Jrlee
CNC Control System Serial Number: F045DA798AE4-1119181352
Post by Jrlee »
It appears to me that the schematic for the Rev 3 PCB is in error relative to relay pinouts at H7 header. Rev 3 shows the COM connections at bottom of the callout for OUT1 and OUT2 respectively. BUT IF you look at a photo from July of 2019 (my machine) it clearly shows the wires at H7 header NOT connected to the lower pin for the respective relays 1 and2. The open connections should be (acording to rev 3 schematic) for the common relay terminal. What is the correct pinout at H7? I appreciate the hellp
Jr
S14938.r2.pdf
(85.71 KiB) Downloaded 7 times
Centroid_Tech2
Re: H7 pinout for Rev 3. Upgrading to Rev 4 and new Relay PCB
Post by Centroid_Tech2 »
The schematic is correct.
