Today normally zeroing my mill at begining of work. After a little job, the Z axis does not zeroing; also after many-many tries to zeroing Z axis, the DRO continued shows 15.935 mm.The other axes zeroing.
What can happened? Any help?
Thanks in advance
Z axis doesn't zeroing
- CNC Control System Serial Number: 0607050819
Re: Z axis doesn't zeroing
Are you stating that the Z axis doesn't move when homing the machine or that the value of the DRO doesn't show 0 after that axis has homed?
The DRO doesn't show 0 after Z axis has homed
I found the problem. The Z axis doesn't zeroing because I made part zero first
Now all are ok.
Thanks for correspondence
Now all are ok.
