extremely frustrated after v5.02 install
eswakon@eas-eng.com
Post by eswakon@eas-eng.com »
I have a new PC. I downloaded and installed a copy of v5.02 on that new PC. It started, I attached the license file and created a report (attached). On the old PC, I was running v4.62 and I attached a report from that installation(about a year old). I had installed v5.02 on the old PC and restored the v4.62 report. I KNOW NOW that was not the correct thing to do but after a few tweaks in the wizard it was working. I created and attached a copy of a report from that installation. During all of these changes between versions I was doing all the appropriate c:/cmd file renaming etc.
I went back to the working v4.64 setup. I then created screen shoots of the wizard screens (what a pain in the a**!) attached. The problem is I was NOT able to get screenshots of any of the screens in the Primary system (see attached png.) When I went to the new 5.02 install on the new PC I had no idea what to put in those settings. I have a lot of input mods. I did those in 2019. I don't remember them.
So how do I get that info back?
eswakon@eas-eng.com
Re: extremely frustrated after v5.02 install
I'm not sure this post had the attachments I referenced so here they are.
report_F045DA79A18B-1205181402_2022-01-21_16-09-05.zip
(692.72 KiB) Downloaded 1 time
Screenshot 2023-06-30 122546.zip
(3.09 MiB) Downloaded 1 time
Screenshot 2023-06-30 161043.png (17.23 KiB) Viewed 1265 times
report_F045DA79A18B-1205181402_2023-06-30_12-12-26.zip
(707.01 KiB) Downloaded 1 time
report_F045DA79A18B-1205181402_2023-06-30_11-49-47.zip
(889.21 KiB) Downloaded 1 time
cncian
CNC Control System Serial Number: A81087B4FFCB-0712192265
Post by cncian »
eswakon@eas-eng.com wrote: Fri Jun 30, 2023 7:20 pm ... The problem is I was NOT able to get screenshots of any of the screens in the Primary system (see attached png.) ...
That is because you have the "Custom PLC" option set to YES in Wizard (Preferences -> Wizard). Set it to NO and your "Primary System" info will be available. If you indeed have a custom PLC, set the "Custom PLC" toggle switch back to YES, after you take screen shots of the data from "Primary System".
eswakon@eas-eng.com
Thank you. Indicating I did NOT have a custom PLC allowed me to capture those screens.
