DM860H driver questions
Posted: Sat Jun 17, 2023 9:17 am
by chris1976
Currently wiring up the centroid acorn and I’m at the Inputs section, Spindle ok= VFD? Drive ok= my drivers??? How do i connect these please
https://www.kocomotion.de/webshop/DM860.pdf
Re: DM860H driver questions
Posted: Sat Jun 17, 2023 11:00 am
by ShawnM
I assume you wired those drives to the DB25 as they are 5v drives. From your link the drives don't appear to have an alarm output so you wont need a "drive ok" input on Acorn. Spindle OK is a input on Acorn that uses the fault signal from your VFD. There's a diagram for wiring a generic VFD to Acorn.
https://www.centroidcnc.com/dealersuppo ... 883.r7.pdf
Posted: Sat Jun 17, 2023 11:08 am
by chris1976
ShawnM wrote: Sat Jun 17, 2023 11:00 am I assume you wired those drives to the DB25 as they are 5v drives. From your link the drives don't appear to have an alarm output so you wont need a "drive ok" input on Acorn. Spindle OK is a input on Acorn that uses the fault signal from your VFD. There's a diagram for wiring a generic VFD to Acorn.
Yes straight into the db25, so I can just use the fault from the relay as per this post? https://centroidcncforum.com/viewtopic.php?f=60&t=8854
Posted: Sat Jun 17, 2023 3:07 pm
by Gary Campbell
Those are open loop drives, so there is no alarm circuit available. Also, leave the enable disconnected.
Posted: Sat Jun 17, 2023 4:32 pm
by ShawnM
Each VFD is different and you haven't told us what VFD you have or shared a link to the manual. We need a lot more info to be able to help you.
Posted: Sat Jun 17, 2023 4:33 pm
by chris1976
Posted: Sat Jun 17, 2023 6:46 pm
by ShawnM
Didn't we go over this already in your other post? It's confusing when you start more than one topic with the same questions.
Posted: Mon Jun 19, 2023 4:04 am
by chris1976
Gary Campbell wrote: Sat Jun 17, 2023 3:07 pm Those are open loop drives, so there is no alarm circuit available. Also, leave the enable disconnected.
thank you Gary
Posted: Sat Jul 01, 2023 4:04 pm
by garybergin288
curious i have similar drivers why do we leave the enable disconnected?
Posted: Sat Jul 01, 2023 6:02 pm
by ShawnM
garybergin288 wrote: Sat Jul 01, 2023 4:04 pm curious i have similar drivers why do we leave the enable disconnected?
They are enabled by default. If the motor locks when you power up the drive it's enabled.
