Setting up a 4th Axis in Acorn and fusion360
Here is how I do this.
After setting up this way you can mill any part in the centric vise on the A-Axis without using a probe for each part.
If using Intercon use all dimensions from the center of the A-Axis and from X0 at the base of the vise jaws.
Boatwrights Workshop
CNC Control System Serial Number: E062347948F9-0324225805
Re: Setting up a 4th Axis in Acorn and fusion360
Post by Boatwrights Workshop »
suntravel wrote: Fri Jun 09, 2023 2:44 pm Here is how I do this.
Great video. Now I need to look at my setup again. I am running my rotary on the B axis.
Blue Elephant 1318-4th axis Rotary, 6hp Spindle with Richauto B58 DSP controller converted to Centroid Acorn, Shopbot Desktop 2418 with 1.25hp HSD Spindle
Epilog Helix 50 watt C02 laser 18"x 24" work area
Graphtec FC8000-30" Vinyl cutter/Plotter
Software: Vectric Aspire 12.0v; Rhinoceros 8 with RhinoCAM 2018; Deskproto 8.0v; Autodesk Artcam Premium 2018; CorelDraw 2020; FlexiSign Pro 10.5v
