Is there a brain for the probe? Also do you have a diagram for the pin out for probe connection.\
got a probe from me bday
- CNC Control System Serial Number: 0917130853
Re: got a probe from me bday
Ok after doing the research I should have done before asking a question I now have the pin connections.
My question is that on your diagram you say that the probe pin 3 (white) corresponds with input 772. Is that the same on Mach3 as the pin number when I set up the probe in Mach 3?
