TT to measure tool diamter
Anyone have any experience using a touch off tool to measure tool's diameter. Any scripts for cnc12 to include updating the tool library?
Pics, Manuals. Specs, Datasheets for build - https://drive.google.com/drive/folders/ ... share_link
CNC12 Mill Pro
All in one CNCPC
Ether1616 Expansion Kit
Centroid Wireless MPG
2 Relay 8 Boards
Stepperonline 3Nm Closed Loop - CT57T Driver
Stepperonline 12Nm Closed Loop - CT86T Driver
Omron Encoder
DIG3D.LP.M Touch Probe
DIG3D.Fix Touch Off
Signal Isolator
CNC12 Mill Pro
All in one CNCPC
2 Relay 8 Boards
Omron Encoder
DIG3D.Fix Touch Off
Signal Isolator
Re: TT to measure tool diamter
That would be of interest to me too. I have a TSR27 tool probe that is able to measure diameter as well as tool length. Perhaps one for the wish list?
Process would be to touch off from left side record as X1 then touch off from right side and record as X2. Formula is then Tool Diameter = X2-X1-TouchOffPlateDiameter. Spindle should be running CCW. Probably not safe for fly cutters, etc however.
CNC12 Mill Pro
All in one CNCPC
2 Relay 8 Boards
Omron Encoder
DIG3D.Fix Touch Off
Signal Isolator
CNC12 Mill Pro
All in one CNCPC
2 Relay 8 Boards
Omron Encoder
DIG3D.Fix Touch Off
Signal Isolator
Indeed - and it would be really nice if this could be automated as part of the automated tool setting macros. It seems unlikely that there would be enough demand to justify it but if we didn't suggest it, our interest would never be noted.
